fans675171a0
Hello, I have recently crashed my drone several times even in p mode Ian's with the distance showing on the screen it still wonders into objects the last one being a steel building and when it hit the ground cracked the landing gear so I decided to replace it, now after installing new landing gear I get a backward vision sensor calibration error, precision hovering and obstacle avoidance may fail message constantly scrolling across the screen, the drone flies fine but sensors still don't stop it from flying into objects even this it shows the lines and tells distances on the screen also if I try to use auto land the drone goes crazy and flies all over the place, I have tried to calibrate sensors and it always says calibration failed, wires are all hooked up in the correct places and all connections are good no broken wires but looking at the sensors they are not exactly centered in the hole, could this be the problem or did I screw something else up ? any help would be great, thanks in advance...
phantom 4 pro, by the way after the crash before I put new landing gear on I never got the error it happened after I had taken it apart... |
