MadFrenchie
Flight distance : 914711 ft
Hello,
I may be way off my rocker on this one but I'm attempting to do something and am not sure what to call it. I believe its called Cable Cam, but not sure.
Here is what I want to do. I have some races coming up shortly that involve racers going down a closed road, I will be flying over this road, at a safe distance from the racers, and from any crowed (not looking for a safety speech here)
What I want to do is set up way points down this road or a pre planned flight path, and then use the right stick of the controller to control the speed of the inspire down this pre planned flight path. Therefore the drone is always following the same path each time, and i control its speed / direction down this path.
I know this can be done with way point mode and set the speed between each point, but that won't work as each racer goes a different speed, so I need to constantly adjust the speed of the drone, and at times totally stop it. So if i can set up a pre planned flight path, and then control the drone manually down this path it would be great.
Can anyone provide me any insight on how this could be done, and maybe a walk through.
Thank You.
