I just lost my Mavic in a second.
123
9036 84 2017-4-20
4wesomeAdam
I figured it out!
Drone Dundee caught and released it. You got lucky m8.
2017-4-23
SkunkWerxs
Flight distance : 231217 ft
lhabdullah Posted at 2017-4-22 07:00
UPDATE
Thank you for all of your concerns. I found the drone the next day at 6am in a parking lot of a mosque. That is about 200m from the take off position. The aircraft itself suffered minor scratches under the camera and deep scratches under the rotors. However, all of the propellers are chipped and the battery also cracked. So, I have thrown those away. Obviously, it was not hit by a plane and it did not hurt anyone. It might hurt a tree on the way down because of broken branches around the landing site before it hit hard on the tar. it probably can fly again but since I have no propellers and no battery, I have no way to test it for now until I ordered a new ones.
lhabdullah,
               I don't believe this thread is still going on ----- I'm happy you gotten your Mavic back ---- You say your worried about it happening again ???? and  but this will still happen. Someday it can happen to you too regardless where you were flying it.
                Your wrong , no experienced pilot would do what you did --- Flying in a NFZ --- consider  yourself lucky  --- DONT DO IT AGAIN --- FlySafe-FlyFree
2017-4-23
lhabdullah
Flight distance : 1486660 ft
4wesomeAdam Posted at 2017-4-23 05:33
I figured it out!
I laughed on this one. Good meme pal.
2017-4-23
fanscb179702
Flight distance : 11240 ft
DroneFlying Posted at 2017-4-22 07:14
I'm glad to hear that you found it and you're very welcome. I'm guessing that the mosque you mentioned was the Dundee Al Maktoum Mosque, correct? In that case it does appear likely to have been blown east by the wind.
I agree that you should be concerned about the disconnection, and I'd strongly encourage you to send the aircraft in to DJI to have them find out what happened. Not pointing your antenna directly at the Mavic could explain it if the aircraft were far away but doesn't explain why it was disconnected at that close range.
1800 feet is close? Whether distance is horizontal or vertical distance is distance
2017-4-29
DroneFlying
Flight distance : 10774613 ft
fanscb179702 Posted at 2017-4-29 21:50
Yes, when you're talking about an unobstructed path between a Mavic and its controller -- as was the case here -- 1800 feet is a short distance over which to maintain a connection.
2017-4-30
123
