fansef1fdb98
Flight distance : 612316 ft
Brazil
Unfortunately, I had the same problem. Apparently, this happened after an update in the dji go 4 app. In the time when I bought my Z4, everything worked perfectly. I got suspicious of being a drone defect and almost triggered the warranty. But yes, it's a problem with Z4, which does not support the new versions of the DJI GO 4 app. This should be some hardware incompatibility problem, as far as I know, on other android devices the dji go 4 app works fine on other devices. The live stream to Facebook also does not work. Deactivating the video cache I can use the drone without having the screen frozen and without the signal to fall, but only works this way. I hope I have helped. |
