fans9ecb62f3
Flight distance : 59711 ft
IN ENGLISH :
Hello,
Sorry for my bad english (Google Translation)
I bought a P4 Pro to replace a normal P4 I was very happy with.
A first P4 Pro had to be replaced before use because the camera looked at the wrong time after unpacking even after multiple attempts to recalibrate.
This P4 Pro has been exchanged by the DJI service and the new one does not suffer from the default of the first one so I made it fly.
On the other hand, the problem is that the image is very unsatisfactory (video H264) and I have just made a new complaint to DJI on this subject for which has not yet received a reply nor even an accused reception.
This is why I come to this forum for the case where what I wish to expose would be known to some of you.
I attach a link to download two short excerpts because I do not know how to do otherwise. (If anyone knows, do not hesitate to do it for me this would be very nice)
Https://www.transfernow.net/74cpg5t6si5x
For those who will have the kindness to watch, you will see that at times some elements of the image seem to float (see the houses in particular file 1).
Permanently there is a flicker that is mostly visible in the lower half of the screen.
There was also an episode of a few seconds in which the image was totally degraded and parasitized, but I have doubts that it could be the propeller because of The conjunction of a gale and the lateral sun (file 2).
Note that I use very new and powerful computers, Mac and Windows, as well as a recent TV also and that I never experienced any problem of visualization with the standard P4 on these different diffusers.
I am sorry if this problem is already documented elsewhere on the forum but, not practicing English, it is not possible for me to search on the forums as I usually do on those in French.
There are other small concerns found, but, for consistency for this forum, I will expose them separately by creating other dedicated topics.
Cordially.
Jacques.
IN FRENCH :
Bonjour,
Désolé pour mon mauvais anglais (traduction Google)
J'ai acheté un P4 Pro en remplacement d'un P4 normal dont j'étais très content.
Un premier P4 Pro a dû être remplacé avant usage car la caméra regardait de travers dès le déballage et ce même après de multiples tentatives de recalibrage.
Ce P4 Pro m'a été échangé par le SAV de DJI et le nouveau ne souffre pas du défaut du premier aussi je l'ai fait voler.
Par contre, le problème c'est que l'image est très insatisfaisante (vidéo H264) et je viens d'ailleurs d'adresser une nouvelle réclamation à DJI à ce sujet pour laquelle ne n'ai pas encore reçu réponse ni même un accusé réception.
C'est pourquoi je viens sur ce forum pour le cas où ce que je souhaite exposer serait connu de quelques uns d'entres vous.
Je joins un lien pour télécharger deux courts extraits car je ne sais pas comment faire autrement. (Si quelqu'un sait, ne pas hésitez à le faire pour moi cela serait très sympathique)
https://www.transfernow.net/74cpg5t6si5x
Pour ceux qui auront la gentilesse de regarder, vous verrez que par moment certains éléments de l'image paraissent flotter (voir les maisons notamment dans le fichier Prob1.mov).
De façon permanente il y a un scintillement qui est surtout visible plutôt dans la moitié inférieure de l'écran.
Sur les trente petites minutes de vol il y a eu aussi un épisode de quelques secondes où l'image est totalement dégradée, comme parasitée mais j'ai un doute sur le fait qu'il puisse s'agir de l'hélice du fait de la conjonction d'un coup de vent et du soleil latéral (fichier Prob2.mov).
A noter que j'utilise des ordinateurs très récents et puissants, Mac et Windows, ainsi qu'une TV récente également et que je n'ai jamais connu le moindre problème de visualisation avec le P4 standard sur ces différents diffuseurs.
Je suis désolé si ce problème est déjà documenté ailleurs sur le forum mais, ne pratiquant pas l'anglais, il ne m'est pas possible de rechercher sur les forums comme je le fais habituellement sur ceux en langue française.
Il y a d'autres petits soucis constatés mais, par cohérence pour ce forum, je vais les exposer séparément en créant d'autres sujets dédiés.
Cordialement.
Jacques.
