Jello Inspire 2 - X5S
1867 3 2017-4-21
Aeriallive
Flight distance : 4054803 ft
I have got in almost all footage jello vibrations effects. I have this with the DJI 15mm but also with the Panasonic 14-42mm.
When I touch the X5S I can feel a lot of vibration coming from the pan motor, Roll and Tilt are vibrating far less.
Has anyone got the same problem?
2017-4-21
Mike-the-cat
Flight distance : 22488593 ft
Singapore
Check if anything is obstructing the motor. If not, you have a defective X5S
2017-4-21
Linh9
Flight distance : 28136 ft
May want to refer to this post below for resolution:
http://forum.dji.com/thread-86628-1-1.html
2017-4-21
DJI-Jamie
Flight distance : 112405 ft
I would concur with Mike. Any visuals you could provide, however, would help to verify the possibility.
2017-4-21
