what if i take off before homepoint recorded?
fansce9f006f
Flight distance : 3583675 ft
Indonesia
So many people saying that A/C will keep the last homepoint recorded intact until the new homepoint recorded, thus causing some flyaway.
Example:
Day-1 i flown my A/C at the "A" city with all normal condition, nothing special.
Day-2 i fly at "B" city few miles away from "A" city in a rush, so i can't wait for the "home point recorded" status, that makes me to take off in ATTI mode.
Suppose RTH triggered in this last flight (regardless failsafe or smart), will the A/C going home to the homepoint of Day-1 ???
If any flightlog data/video/review about this, please be kind to show me.... [emoji4] [emoji4] [emoji4]
2017-4-21
Nigel_
Flight distance : 388642 ft
That might depend on which aircraft, which firmware and how you fly it.
For example, in this log from a P4, the home point gets set automatically after take off, at 78ft altitude, however the aircraft thinks that it is still over the take off point, although I'm not sure how it knows that: http://forum.dji.com/forum.php?m ... &fromuid=316867
Best to check that it is set as part of your pre-launch checks.
2017-4-21
Labroides
Flight distance : 9991457 ft
If you launch before the GPS has had time to acquire enough sats for a fix, or from a location where the sky is blocked,  your Phantom will be in atti mode until it gets enough sats for a fix.
Example ... you launch from under tree cover without GPS, fly up and through a gap.
Once up there, your Phantom gets a fix and records the point where this happens as home.
2017-4-21
Nigel_
Labroides Posted at 2017-4-21 03:26
That's not the case in the example I linked to, that launches in P-GPS mode but sets the home point later.
I guess it requires a certain GPS quality level before it records the home point.
2017-4-21
Quamera
The Phantom will forget the Day-1 homepoint as soon as it is turned off so it won't try to return there on Day-2.
2017-4-21
Labroides
Nigel_ Posted at 2017-4-21 03:54
The Phantom cannot be in P-GPS mode until it has acquired enough GPS satellites.
Until then, it's in atti mode regardless of the switch position.
Once it has enough sats, it has position holding and records home.
2017-4-21
fansce9f006f
Indonesia
Nigel_ Posted at 2017-4-21 02:06
For example, in this log from a P4, the home point gets set automatically after take off, at 78ft altitude, however the aircraft thinks that it is still over the take off point, although I'm not sure how it knows that: http://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=92471&pid=767673&fromuid=316867
Thanks for your reply Nigel_,
as far as i know form the internal flight log of my Phantom3Adv, there is blank value on the latitude and longitude column until it gain a GPS lock for the first time which means it records the home point.
but why i am asking this while i already has these data is because many people still believe that UAV always keep the last homepoint until it get the new one. that's why i wanna know wether my knowledge is applied only on Phantom3Adv or what.... Thanks again....
2017-4-21
fansce9f006f
Indonesia
Yes, you're right... and i've done it several times in some situation...
But what i'm asking is..... before the UAV get the HP at the current flight, will it keep the HP coordinates of the previous flight intact ?
Thanks,..
2017-4-21
fansce9f006f
Indonesia
Quamera Posted at 2017-4-21 04:06
Thank you very much....
That's exactly what i have in my mind.
2017-4-21
KM5RG-Robert
Flight distance : 2075213 ft
Test it and let us know.
2017-4-21
Nigel_
fansce9f006f Posted at 2017-4-21 05:20
I think there may be some confusion because the map in the Go App will come up at the last location until a new GPS location is acquired.  I've see the map be in the wrong country.  However I don't recall ever seen a log with the home point in completely the wrong place, and if it was then it would instantly do a low battery return to home and the problem would be noticed.
Every time there is a problem with the home point it is because someone has set it from their mobile device and they can sometimes be wildly inaccurate, especially if they don't have a GPS receiver and are using the mobile signal to guess their location.
I'm not convinced that the home point is set on the very first GPS fix though, it may wait for a good quality fix before setting the home point.
2017-4-21
fans987d278a
Flight distance : 124180 ft
Nigel_ Posted at 2017-4-21 05:54
Why one would not wait for the command- "Home point recorded", if somehow home point isn't recorded, say until you get 20-30 mters away, maybe because bird doesn't get satililte fix,  your home point would then be, 20-30 meters away from you!
But, don't worry about the day before's flight, once you turn off your bird, the last home point is history, so no worries about it going back to a previous  flights home point
2017-4-21
Nigel_
fans987d278a Posted at 2017-4-21 06:30
I am not sure that turning off resets the home point?
I think it may be removing the battery that resets it...
2017-4-21
Eric13
Flight distance : 13982031 ft
"Every time there is a problem with the home point it is because someone  has set it from their mobile device and they can sometimes be wildly  inaccurate, especially if they don't have a GPS receiver and are using  the mobile signal to guess their location."
I don't think something like a 'wild' homepoint is possible.
If there is no GPS signal available on the device, home point cannot be set to RC. Same thing when AC has no GPS.
I have tried this indoor (with my device having a SIM card and good mobile signal):
2017-4-21
Eric13
That might make the problem even bigger.
If there is no GPS, latitude/longitude are set to "0" values. I've checked that in the csv file.
The map below shows where those coordinates are.
I have been digging a lot into HP/RTH/GPS topics and find it fascinating.
On my next flight I'll start from a barn or something with no GPS and then fly into the open.
Then I'll trigger RTH. Will let you know if the bird is on its way to Africa :-)
2017-4-21
DJI-Jamie
Flight distance : 112405 ft
You pretty much hit the nail on the head. The GPS count needs to be stable for at least a few seconds or so before it's properly recorded.
2017-4-21
Labroides
"I'm not convinced that the home point is set on the very first GPS fix though, it may wait for a good quality fix before setting the home point."
A regular hand-held GPS can give a dodgy 2D fix with 3 sats and a reasonably good 3D fix with 4 sats.
The Phantom has a higher standard and requires either 6 GPS or 6 Glonass sats before it registers a fix.
When the Phantom has a fix, it's a good fix.
2017-4-21
marpir
Flight distance : 14908 ft
Portugal
HOME POINT.
Suddenly my PHANTOM 4 began last week with a problem: i can't fly becausr the RC "Disconnects from Aircraft".
And even woest wheb "Aiscraft Diconnnets" the Drone assumes HONG KONG as HOME POINT !?!?!.
One of thesse days i was just loosing him, i was very lucky to find him, with a GPS Finder 809meters away from me!
2017-5-2
marpir
Portugal
marpir Posted at 2017-5-2 19:35
HOME POINT.
Sorry my poor and rusty English.
Mário Pires
Funchal - MADEIRA Island - Portugal
2017-5-2
marpir
Portugal
Where is "DJI Support" to answer the problem of "Home Point = HONG KONG" i submit?????????????????{:4_154:}
2017-5-3
fans7ee265a6
I have tried to start drone up in atti mode to let my bird warm up while walking down to the beach and it still updates the homepoint. When I get to the beach I have to power off and power back on again to update homepoint again.
2017-5-14
Rabe
Flight distance : 967907 ft
Last time I started my P3S I took off, before ir found enough satelites, so it started in atti mode. During the flight, the status lights went green an the friendly voice told me "home point have been updated..."
So, when you take off and fly before home point is recorded, your AC will remember that location as home point where it is when it has found enough satelites.
2017-5-14
singgiha
Indonesia
i have a brief test about this... --->
Conclusion :
homepoint will be reset to -null- everytime we shut down the A/C.
there is no chance of returning to home point of the previous flight, unless we keep the A/C turned on while moving to first location to another.
2018-8-16
