Mavic Pro and batteries in cabin bag
234 19 3 days ago
chrismid2599
Beginner
Flight distance : 126859
Hi,
I am planning to take my Mavic with me to Jersey, Channel Islands next week on Easyjet from the UK. I'm carrying the Mavic in my cabin bag. I know that there's no issue with flying with the Lithium batteries as they are under 100wH. However, apart from protecting the batteries from short circuiting (I bought connector caps from China), there's nothing to say that the batteries have to be protected, for example, in individual bags as I have seen mentioned in a number of online boards.
What I'm wondering is do the batteries have to be protected in a bag, or is a bag a way of protecting the batteries from short circuit.
Also, I'd be interested in hearing if anyone has carried a drone on Easyjet before. Did you have any problems?
Many thanks.
3 days ago
Xman1
Hobbyist
The manual talks about this in that you should discharge them to less than 20% before transporting them on an aircraft.
3 days ago
FrequentFlyer
Intern Pilot
You can either put them in individual bags for you can cover up the terminals and you should be fine.
3 days ago
FrequentFlyer
Intern Pilot
Xman1 Posted at 2017-4-21 05:47
20% is just a suggestion for traveling on long trips it dont say anything about when flying in aircraft's. Although some airline's recommend discharging to 50% when traveling.
3 days ago
theinstanic
Beginner
Argentina
I'm going to travel in two months and it's going to be my first time with the drone. Should i take the battery off the drone or its to ok to have one pluged there and the other two in the fly more bag?
3 days ago
Xman1
Hobbyist
You should be fine.  Three batteries is allowed:
Carry-on         Maximum 100Wh, passenger can take 2 spares up to 160Wh each, not exceeding 320Wh. No check-in allowed.
Note:  Since 2016, lithium batteries can no longer be carried in passenger aircraft as cargo.
3 days ago
FrequentFlyer
Intern Pilot
theinstanic Posted at 2017-4-21 06:25
What airline are you traveling on?
3 days ago
chrismid2599
Beginner
FrequentFlyer Posted at 2017-4-21 06:17
Is it actually possible to discharge Mavic batteries? I usually use discharge function on the DJI Hub for Phantom 4 Pro batteries to discharge to 50%, but doesn't appear to be such function on the Mavic Hub.
3 days ago
FrequentFlyer
Intern Pilot
chrismid2599 Posted at 2017-4-21 07:02
Per manual it just says to fly around to discharge your battery, or depending on your settings it should discharge to 65%, after sitting for 10 days, which will probably show 2 lights on the battery. Most airlines dont even check the battery percentage.
3 days ago
FrequentFlyer
Intern Pilot
Xman1 Posted at 2017-4-21 06:29
This is incorrect, as the requirements change per airline.
3 days ago
Xman1
Hobbyist
FrequentFlyer Posted at 2017-4-21 07:46
True that.  Same with the discharge requirements.
You can't ship lithium with anymore than 30% charge, so I would think to err on the side of caution when flying.  Each battery and its charge is potential energy in the event over overheating or damage of some sort.  Less charge == Less chance for catastrophic fire resulting from any damage or overheating.
I don't trust Lipo's all that much as they are contained in little plastic bags and are not very stable.
Edit:  For those that don't know, Lipo stands for Lithium Polymer.  It is not a standard Lithium battery but is one designed for the most energy density in the lightest space.  Most electric aircraft will use a Lipo for obvious reason - lightweight and great energy.
3 days ago
theinstanic
Beginner
Argentina
FrequentFlyer Posted at 2017-4-21 06:34
Aerolineas Argentinas, are domestic flights here in my country.
3 days ago
FrequentFlyer
Intern Pilot
theinstanic Posted at 2017-4-21 08:12
I would read the info in link below to ensure you are following your airlines rules.
http://cargo.aerolineas.com.ar/en-US/envios_especiales/Litio
3 days ago
FrequentFlyer
Intern Pilot
Xman1 Posted at 2017-4-21 08:02
Carry-on / Shipping 2 different things.
3 days ago
theinstanic
Beginner
Argentina
FrequentFlyer Posted at 2017-4-21 08:21
You made my day, thanks for being so helpful!
3 days ago
chrismid2599
Beginner
There is nothing on the airlines website about batteries having to be at a certain charge level. It only says about restrictions to batteries that have a wH rating of 100 of over. As the Mavic batteries are under 100wH. There doesn't seem to be an issue here.
3 days ago
FrequentFlyer
Intern Pilot
chrismid2599 Posted at 2017-4-21 09:56
Did you not read this section?
LIMITATIONS
The Aerolineas Group established that can only be accepted Lithium Ion batteries with the following exception acceptance limits. * The  small Lithium Ion Batteries  must not exceed  20 Wh  of energy charge. * The  Lithium ion batteries  can not exceed  100 Wh  power load.
3 days ago
chrismid2599
Beginner
Sorry, what I meant was on the airlines website, as in the airline I'm travelling with.
3 days ago
Xman1
Hobbyist
FrequentFlyer Posted at 2017-4-21 08:22
I think you missed my point -  what I was getting at is you have a mavic getting tossed around in an airliner.  Potential energy == potential fire with the slightest damage on a LiPo.  It is not like you can just pull over to the side of the road and toss it out.
I don't think I would want to fly with someone with fully charged batteries either.
The point:  Be safe.
3 days ago
Tealk
Hobbyist
Flight distance : 17960
Romania
This is the regulations from IATA
battery must be Discharge at 30% and cannot be carried in cargo bags, just in you hand bags!! ...and no propeller at cabin...just in cargo bags ....it loks like a plastic knife
everyone must read iata regulation
lithium-battery-update.pdf
47.48 KB, Down times: 0
3 days ago
Close
DJI RecommendsPrevious /1 Next
