Battery Explosion
8674 37 2017-4-21
Central Maine D
Flight distance : 1046680 ft
Someone tagged me on Facebook because they knew I had a P3P.  They'd seen this video about a battery exploding causing a fire.
2017-4-21
RedHotPoker
Flight distance : 165105 ft
That is a scary occurrence.. Never heard of DJI batteries going off.
I wonder if it was a third party unit?
Aside from the property damage, thankfully, no one was injured...
RedHotPoker
2017-4-21
method007
Flight distance : 110449 ft
An inspire battery caught fire in carry on luggage a few years back.  That's all I recall.  Sell enough of them, it's bound to happen.
2017-4-21
Mark The Droner
Flight distance : 2917 ft
Note the guy on the bottom left knew what was important - regardless of the circumstances, he wasn't about to let go of that sandwich:
2017-4-21
DJI-Jamie
Flight distance : 112405 ft
RedHotPoker Posted at 2017-4-21 09:45
It's a rare occurrence, but they can have the same risk as any LiPo battery if not taken care of properly. 3rd party batteries could have been a possibility, but I'd be speculating.
2017-4-21
DJI-Jamie
Mark The Droner Posted at 2017-4-21 10:32
https://www.youtube.com/watch?v=fF9fhlr9S5s
It must have been a pretty good sandwich...
2017-4-21
Geebax
It is a pity that most of the advice given in that report is pure BS. LiPo batteries may catch fire, they do not explode. And the guy advising using the right battery matched with the 'right sized' charger is full of it too. Seeing the item was about a DJI battery, the charger is automatically the right size.
2017-4-21
RedHotPoker
Geebax Posted at 2017-4-21 17:03
Talking about DJI batteries and appropriate chargers, made me think of Solentlife, and his using alternative chargers, that balance and override the intelligence quotient.
I only hope, that who ever had this frightening experience isn't jaded or scared off from enjoying RC hobbies. This has to be a once in a lifetime experience, one in ten million... Much like winning the lottery.,
Only with bad luck though. ;-)
RedHotPoker
2017-4-21
RedHotPoker
DJI-Jamie Posted at 2017-4-21 16:47
Is it only during charging the intelligent flight pack, that over considerations should be made?
RedHotPoker
2017-4-21
Eric13
Flight distance : 13982031 ft
This here is interesting. Looks like after a bath the battery seems to be a continuous hazard.
I'm wondering how to properly get rid of it:
http://www.phantompilots.com/threads/battery-fire.111277/
2017-4-25
KM5RG-Robert
Flight distance : 2075213 ft
Eric13 Posted at 2017-4-25 05:33
Maybe just take it out into an open area and throw it in a campfire?  Once it has burned it will be safe. It would be exciting.
2017-4-25
KM5RG-Robert
I beg to differ. It may not be an explosion compared to C 4 but it can explode as any container under pressure can.  It happened to me with a Li-ion battery. It was one of those compact car jumper batteries. After the car started the battery began sizzling and I went to disconnect it but it exploded and caught fire just as my arm was over it. Had some burns and bits of plastic embedded in my arm. Fire extinguisher put it out but they sure do make a mess.
2017-4-25
Pocket Sized
KM5RG-Robert Posted at 2017-4-25 05:57
Heavy duty Li-on cells typically have a very thick metal housing to protect them from impact damage. These can hold a HUGE amount of pressure before bursting, as you discovered the hard way.
Flight batteries have a thin foil covering the cells, so they tend to rupture before there's enough pressure built up for an explosion.
2017-4-25
Mark The Droner
Whether Lipos explode or not depends on how you define the word.  IMO, the word explode is a good word when describing ignited liipos.  It's a pressurized ignition which is why lipos should be stored in a well-vented flame-proof container which should be kept away from other things that may ignite.  Know that upon ignition, the flames will shoot wildly out of the vents.  The fewer the vents, the more wildly flames will shoot out.
In addition, if I may borrow a quote from Maximum PC's July 2002 issue:  "If the lithium inside the battery comes in contact with water, it can mess you up bad ..."
https://books.google.com/books?i ... p%20bad&f=false
2017-4-25
Geebax
All right, I will further qualifty it and say the batteries used in DJI aircraft do not explode. The word 'explode' is a favourite term used by the media because it confers a bigger incident than actually occurred. In other words, alternative facts', the new Trump-esque term for media lies.
2017-4-25
KM5RG-Robert
Pocket Sized Posted at 2017-4-25 08:50
That's good to know.
2017-4-25
TM.SkyDrone1
Flight distance : 867257 ft
Never heard of this happening until today while flying at 75 feet my P3P with only dji Products exploded in mid air sending my drone crashing to the ground completely destroying it.  When I called DJI they said they never heard of this... Humm that is not true.  This accident was not at all my fault I was in clear air space when this happened.  They say the battery is past its warranty; but it isn't an issue of warranty it is an issue of defective battery.  As I said I only use DJI equipment.  I do help they handle this and replace the drone that is destroyed and the battery that destroyed it.
2018-10-29
TM.SkyDrone1
2018-10-29
Mark The Droner
I've never heard of it either.  Not in mid-air.
The only explanation that I know of is the battery was swollen, probably quite a bit swollen.  I don't think there is any other explanation.
Swollen batteries must be retired.
Sorry for your loss.
2018-10-29
TM.SkyDrone1
Mark The Droner Posted at 2018-10-29 16:44
nope wasn't swollen I do major pre-flight checks.
2018-10-29
Mark The Droner
It looks like it popped like a balloon?  No evidence of fire or scorching?  Very strange.
2018-10-30
solentlife
Flight distance : 1087530 ft
Latvia
RedHotPoker Posted at 2017-4-21 19:32
RHP - you really need to be more careful in your wording ...
The Alternatve charging I talk about when post warrants does NOT over-ride any DJI item or function in any way whatsoever. The charger acts exactly the same as the DJi charger as a power source. The difference being that with the Programmable LiPo charger - you have a digital readout telling you what mAh have gone in, amp rate and voltage at that moment.
It is in fact SAFER than a DJI charger - because if any fault occurs - it will automatically shut off - unlike the DJI charger which in fact is only a fixed voltage PSU.
As to balance function - DJI prevents any access to balance lead to actually do that ... shame - but thats the way they want it.
I have absolutely no objection for people to quote / mention what I post - but please get it right and not try to imply its unsafe ...
Nigel
2018-10-30
solentlife
Latvia
Mark The Droner Posted at 2018-10-30 02:19
Yes very strange ... looks still square - BUT unless its the photo ... the end of the foil packets is decidely black !
In the packs I have taken apart in the past to check out functions / access / identify actual cells ... and tests ... all foil packets were silver foil as near all LiPo's I have dismantled.
Very strange.
Nigel
2018-10-30
solentlife
Latvia
Mark The Droner Posted at 2017-4-25 09:20
Actually because the Lithium is in compound and not in elemental state - it dos not auto-ignite in contact with water.
I made the same assumption many years ago when first seeing Lithium batterys ... but tests and also technical references show that its not the case. You get a 'fizzle' but that's because of the electrical activity.
The fire and its shooting out is purely due to agents oxidising in the cells and the foil envelopes creating pressure packs ... once the initial flame thrower effect has vented and pressure reduced ... you get the hissing flame jet.
A group of guys including myself actually tried to get a Lithium cell to auto-ignite with water in punctured packets etc. - it failed totally. We had to physically abuse it to get it to start.
nigel
2018-10-30
bob37
Flight distance : 260384 ft
I always change my P3A batteries in a safety bag and in a hood.  I also never leave it unattended.  I also have never had any trouble (thank goodness).
2018-10-31
DJIJAKOB
Flight distance : 740577 ft
Norway
There are plenty of third-party batteries for P3 out there on the market. Also LiPo batteries have to be treated carefully, but of course things like this should never happen.
2018-10-31
solentlife
Latvia
DJI have basically put together an 'idiots' battery pack as far as possible.
The board fitted to the front is designed to do three things :
1. Provide interface for telemetry data back to you on the ground
2. Provide interface to monitor power to system
3. Provide charge / discharge control.
The user is asked to charge in controlled environment and not subject the pack to physical abuse.
The part that DJI cannot design against - is the fact they are using not only LiPo ... but a High Voltage version. LiPo's are normally rated at 4.20V per cell - but DJI and other LiPoHV are rated to 4.35V per cell. Because the max ceiling of normal and HV versions is the same 4.35V - the HV version has no margin basically for error. (Please do not think to start charging normal cells to 4.35V - you will quickly bloat them and have potential hazard).
The extremely high output that LiPo is capable of - means that any fault or short can have devastating effect.
I know people who take greater care in their use of LiPo's than I ... and still have 'events'.
My pal who's Cessna decided to have a 'fire' ....
as example ... no reason could we find for it happening ... but there it was ..
Nigel
2018-10-31
djiuser_1GyzdjPip7vQ
Ukraine
Yesterday, may Mavic Pro Platinum have a bad day. On a 97 meters height, battery exploding.
Battery have only 35 cycles. I use only original charger from my "Fly more" box.
2019-11-17
Mark The Droner
I like the comment in the top video at 1:15
2019-11-17
Ukraine
2019-11-17
RedHotPoker
djiuser_1GyzdjPip7vQ Posted at 11-17 03:17
Post pics of the battery.
RedHotPoker
2019-11-17
Ukraine
Hi, only now i get back my battery.
More photo later.
2019-11-21
djiuser_1GyzdjPip7vQ Posted at 11-21 23:57
More photo later.
[view_image]
Hi there, sorry for what happened, are you sure the battery exploded? It seems split open after crashing. Did you contact our support team to start a ticket?
2019-11-22
DAFlys
method007 Posted at 2017-4-21 10:24
I've had two 18650 cells explode on me, they go off like a firework and destroyed what they were in,  and I see from the tear down thats the same battery that the Mavic Mini now uses.
2019-11-22
solentlife
Both batterys in the uploaded photos appear to be crash damage - not 'fire or explosion'.
A LiPo that has suffered fire is 'unmistakable' .... its a charred wreck ! Not the clean popped jobs shown in posts above.
The Phantom battery - I would suspect could have puffed while in flight ... causing fracture of the battery mount area ... leads to connection break and in the immortal Monty Python Flying Sheep words :
'It didn't as much fly as plummet'.
The impact of course then doing its worst.
But of course I may be wrong.
2019-11-22
Ukraine
when the signal went missing, I saw the battery flying to one side and the body to the other.  There were no birds nearby, and it was 97 meters high.
2019-11-22
Ukraine
probably not to call it a exploese, the battery has increased
2019-11-22
solentlife
Both that and the photos suggest to me a non fire situation ... why the battery ejected could be as I say due to battery expanding OR some other factor causing it to break out from its mount ... the fact you saw the battery and model separate in the air tends to support that. And of course the battery photos ...
If that battery had exploded and flamed - the photos would be completely different. AND the model would show signs of fire.
2019-11-22
