dronist
Nope nothing here. Depending on how high you are wind gust can vary widely from the surface. What you can do is when you take off, just take off for about 3 feet, move the AC IN ALL DIRECTIONS and then see if you notice any drifting it it did then look at your sensors, IMU and COMPASS ansee the readings. You might need to re-calibrate both. COLD IMU on a 100% leveled surface and then calibrate compass away from metal and interference and try the ssame thing again. Good Luck! |
