Mark The Droner
Flight distance : 2917 ft
Which antennas? The two aircrafts you mention use two different freqs for control, and each requires an antenna designed for that freq. You can't swap out antennas designed for one freq and use them for another freq.
If you're trying to take out the control antennas on the P3S and replace them with the control antennas on a P3P, it sounds like a really bad idea.
If you're trying to take out the FPV antennas on the P3S and replace them with the FPV antennas on a P3P, how will that increase distance?
Re the latter, if your goal is to increase FPV range, it sounds like a reasonable plan. My understanding is the 2.4 antennas on the P3A/P are better than the 2.4 antennas on the P3S.
