Ex Machina
Flight distance : 1806362 ft
Oops, you're right.
Here's what the DJI Fly Safe page says:
NFZ will in many cases warn you about these areas if you fly towards them, or try to takeoff within them. In certain locations, the device will automatically be prevented from takeoff, or if already in flight towards the location, will pause at the boundary and not enter.
Moderators have stated that the closer you get to the boundary, the more agressive the behavior willl be, and while I've been unable to nail down the exact expected behavior from DJI, that's been my experience. I was able to take off very close to such a boundary, but once in the air, the plane automatically started to land. A few feet closer to the boundary and I was unable to lift-off at all. In other locations, I could take off but when I approached the boundary the RC complained and the aircraft paused location.
I think that if you are in sports mode and inertia takes you beyond the boundary after braking kicks in, you will only be able to fly it back out across the boundary, but go no further into the NFZ, so in this case the behavior would be as described by the Flight Limits, which makes sense since the difference in only in who is setting the limits, you or DJI.
