battery
559 3 2017-4-22
iggy120
Hi There
My P4 took a tumble and the battery poped out and hit the deck when the drone did
Now the battery wont take charge.
I put it on charge and everthing starts out as normal but then it just goes dead and all lights go out.
No its not fully charged.
It flashes the first green light when tested.
Any ideas ???
cheers Ian
2017-4-22
DJI-Jamie
Flight distance : 112405 ft
It sounds like there's something disconnected internally or slightly skewed to keep a solid connection to the charger. I wouldn't recommend using it any further.
2017-4-22
Quamera
DJI-Jamie certainly has the safest advice but no one wants to throw out a good battery. Firstly check the line of connectors to see if any are out of alignment and carefully straighten them without shorting any others. Put it in the AC and see what the app says about the battery, (don't try to lift off) if it checks out ok but still won't charge open it up and look for a disconnected wire. Let us know how you go
2017-4-22
iggy120
Quamera Posted at 2017-4-22 19:56
Thanks for the advice
How do I open the battery Up?
2017-4-22
