Roger45
South Africa
Donnie * Posted at 2017-4-24 04:37
I was not aware that 1.3 RC would work with 1.6 AC so I am a bit surprised , It must have not been a Mandatory RC update at that time . You can see my chart that I posted but it may have an error or like I said the RC update may not have been Mandatory . As long as you can start the Moros your good to go !
Thanks for confirming that , also what version does the camera say it is at on the "about " page as well, sorry I should have asked you that before . Thanks Donnie that helps a lot, i am a first timer inspire user but have many years rc experience and 2 years phantom and s800 experience, granted flying only 3 times a month during those periods.
So far the rc works with the 1.6 firmware, i confirmed i picked up my satteleites as well and it showed battery voltage fine.
I don't want my range to be limited, i'm not going to go that far but i don't like it being limited, and if there is no issue ie motors shutting down (i've heard someone said on a certain firmware and certain atmospheric, wind conditions the motors will shut down" but if there's no such issues or that strange P-atti experience where users experience the craft drifting away in atti mode but in calm weather, and they have to really fight the aircraft to bring it back. If V1.6 is void of that, i'd definitely like to keep it there.
I will check the camera version for you, but how do you check what version it wants to upgrade to, i'm afraid when i click on that red line where it says upgrade needed, it will start to upgrade, and i don't want that as i would not be able to revert. If i do decide to upgrade in future, i will follow your guides 100% thanks for the tips so far on doing it, aircraft first, everything else off !
Will check the versions for you when at home tonight and craft connected.
