Punchbuggy
Flight distance : 483166 ft
Just to clarify all of the above, battery firmware is applied as part of a craft firmware update. I don't recall that all craft updates require to update the battery, however. You'll know when it is, when the two middle battery LEDs light up with one flashing - that is an indication of battery reprogramming.
If you're using Assistant 2 to apply the craft firmware (which I'd always recommend over using the RC/app as that's reliant on a good WiFi connection), once the update is complete, power down the craft, swap batteries, power the craft up again, and refresh the firmware to same level. Do that for each battery you have. |
