blackcrusader
Flight distance : 689774 ft
Taiwan
OK Altitude and max height the drone is capable of are two different things. I own a P3S The drones have a firmware limitation of 500m or 1640 feet from your launch point. DJI Drones have a 6000m altitude capability which means to fly at say 3000m you need to be at least at 2500m altitude and use the 500m max height the drone can use. To fly at 6000m you need to be somewhere at 5500m. Also once to fly that high and also add in distance you will need an extra 5 minutes to get to distance and altitude and still be able to return home assuming you didn't fly with a tail wind at 50 mph into the distance as some have done for the drones never to return because they don't have the speed or remaining battery power required to come home so go to low battery and autoland. Some ave had this happen over lakes. Wet sunken drone stories abound on these forums.
There are other issues such as laws in the country you fly, wind speeds which you cannot detect speed or direction, flying out of line of sight especially if you are like me and go cloud surfing. 500m is all I have ever needed to clear the clouds as I get to a high enough altitude to fly my drone above them. Other factors at altitude are temperature and perhaps other aircraft. |
