Antonio76
Flight distance : 144403 ft
Denmark
DJI makes two different sets of prop guards, the older is for the P4, the newer one is made for the P4P, and does not interfere with the sensors (on the P4 the sensors are disabled when the prop guards are on), and the mounting slots seem to be non compatible... so which kind did you get? ------ rereading your post I understand you got the right ones :-) Possibly there is some excess plastic or burrs that you could shave down a bit?
