Thanks for the reply! I was really hopeful there for a minute.... alas, unless I am going bonkers.... Today I fired everything up, same firmware, nothing changed etc. and I now have even less settings
This only seems to be in the 'HD' section of the GO app.
My ipad region was set to UK, so I changed that to US, but I still only have the options in this pic - so there are loads missing??
Things (that I can remember) that where there but are no longer visible:
Picture in picture options
Transmission quality
Select channel
App output mode
Enable HDMI/SDIOutput port
Output mode
Output format
OSD settings
Signal Diagnostics
note all these things were available previously.
To confirm my setup:
Ipad mini 2 - latest IOS 10.2 (ive just seen a new IOS availble 10.3.1 to I will try updating that too)
N3 - latest firmware
LB2 - latest firmware (air and ground)
X3 (via matrice mount) - latest OSMO firmware
Everything seems to be working (bar camera firmware notice in Go app. But of course I cant update the firmware as its already on latest verison).
Can anyone else using this setup confirm what they have on their app please?
I guess the 'enable SDI' one has gone because I am running the channel expansion kit in this LB2, but the other missing options (odd layout etc) should still be there no?
HI,
Just tested mine and similar, however with experimenting I found if you set the slider to 50% the options returned under output device. Had to be 50%.
Ok I can confirm the following options vanish when you have channel expansion kit fitted (at least they re-appear when I remove the channel expansion module):
Output device, mode and format
OSD settings
Signal diagnostics
and Picture in Picture
DJI can you confirm if this is correct / as expected?
