Micro SD card will not eject
5740 13 2017-4-25
Wellsi
Flight distance : 8330187 ft
Hello again guys
My new Mavic will not eject its micro SD card.  I know the card sits fully inserted when fitted, and you need a thin flat item (like another micro sd card) to push it in to eject, but mine will not eject at all.
The slot is so narrow I see no way to use anythign like tweezers to get this card out.
This means the only way I have to transfer files is via the USB cable which takes 10 times as long.  It also means I have no way to upgrade the card.
Has anyone esle suffered this?
Cheers
Ian
2017-4-25
PHL
Flight distance : 1044062 ft
Mine ejected very easily buy pushing in with my nail (short nails at that). If you can transfer, it must be in the correct way, but may be slightly askew and jammed.
2017-4-25
fansbd8cc3e1
Hi,
I had the same problem.
Use a tweezers with pointed ends.Spreize the tweezers and go with the pointed ends horizontally to the two ends of the SD card and pull them out with little force from the slot.
I hope you succeed
Greeting Heinz
2017-4-25
Dinner
Flight distance : 146647 ft
Austria
I had the same problem with my new micro sd card. It fixed itself after i ignored the problem and took my mavic for a flight. I think the vibrations from the flying mavic fixed the spring for the sd card.
2017-4-25
CuaC
Flight distance : 369626 ft
Are you sure you didn't insert it the other way around? It goes with the contacts up (which is not natural to me)
2017-4-25
Hi lan, please try to rub the SD card with fine sandpaper gently.
2017-4-25
Wellsi
I'm travelling at the moment so don't have the tools to try....  Yes, the card is in the right way as it's recording fine, but I can't really rub it with sand paper as it's in the slot...  I'll try with fine tweezers when I'm back home....
Thanks
Ian
2017-4-27
pedrodinis
Flight distance : 896476 ft
Portugal
When I got mine, it had the same problem. Try jiggling it with a needle or something pointy. Once I got it out, it worked normal again.
2017-4-27
Zach_C
Just had that issue - fixed it by getting a pin ( you could use any fined ended object) then just placed the pinhead to the right of the SD card then pushed it to the left a little. Do the same on the left side if the right didn't work...
____
Good luck!
2020-4-21
Cher
Flight distance : 1377087 ft
I have the same issue. This is my 3rd mavic drone and I'm not sure why, all of a sudden, my micro SD card is struck and has to be removed with tweezers. I've changed SD cards to ensure it was not a faulty card. Frustrated, for sure!
2020-8-20
Cher
As an update to my last post on 8/20/20, the second micro SD card was also stuck in the aircraft. Further, I was not able to format my SD card when I used my drone the next time and had to pull it out again, with tweezers. DJI Customer Service said to send in my drone for repairs, which is impossible because I use it every day for work. I've had this drone for 13 months and this should not be happening...very disappointing!
2020-8-24
Geebax
Cher Posted at 8-24 09:00
So DJI service offer to fix the aircraft, but you are too busy to send it in. Yet you are not too busy to whine about it?
2020-8-24
GaryDoug
Flight distance : 1264639 ft
Geebax Posted at 8-24 14:46
Whining only take a few minutes. Returning the drone takes an eternity. Time is a variable, Einstein further proved it, look it up.
2020-8-26
Kamugözü
Turkey
Same problem. Try to insert a pin from left side (when looked from top of the drone) of the card to release the latch.
2021-8-5
