Emergency Parachutes System for Inspire 2
3161 5 2017-4-26
Arrow1969
Flight distance : 400577 ft
http://www.flyingeye.fr/accessoire/parachute-inspire/
2017-4-26
Donnie *
Flight distance : 3636782 ft
Very cool , do you have it on your system ?  Looks like a double parachute  type system, I think this is a great Idea for the Inspire AC as they are heavier than the others and could cause damage  to the AC and the area of Impact , ( I dont  even like to think about it ! )
It is a bit pricey though but if you did this for a living it would be worth it .
donnie
2017-4-27
Sharif
Flight distance : 621312 ft
Anyone know if the system can be set to auto deploy in the event of a sudden increase in negative g-loads...IE: falling out of the sky?  I'd hate to be responsible for pushing the button to save my own aircraft especially if I am not looking at the craft at that exact moment.
Transalation for English speakers:
Option for S2 and S3 homologation including a dual high-speed parachute, a circuit breaker, an alarm and a radio trigger secured for INSPIRE 2.
The parachutes are removable in less than a minute.
The center of gravity of the Inspire is retained.
Redundancy of the parachutes for a totally infallible system.
The INSPIRE lands on its 4 feet, when the parachute trips, to avoid the breakage of an arm or a landing gear (which would require an expensive repair ...)
Works correctly from 15 meters in height thanks to the pyrotechnic technology borrowed from microlight.
Reminder: the cut-out that controls the automatic stop of the engines is essential for the proper operation of a parachute and is compulsory for the S2 and S3 homologation of the INSPIRE 2 (its weight exceeds 4kg in order of flight).
Weight of the complete system: 350g
High-tech materials: carbon and stainless steel.
Requires a workshop return for installation.
Returns to the INSPIRE bag without disassembling the parachutes.
2017-4-27
DJI-Jamie
Flight distance : 112405 ft
That's pretty neat.
2017-4-27
Mobilcams
Flight distance : 2907674 ft
I wonder how high up you have to be for them to be effective though..
2017-5-13
fans4f8954b4
Flight distance : 18275925 ft
Mine is in workshop for installation.
2017-5-13
