Donnie *
Flight distance : 3636782 ft
dcobb23.me Posted at 2017-5-5 18:25
I did the things you mentioned here and it did seem to improve, of course environment always seems to play a large part. I still was getting those "hits" where the screen turned dark. My manual channel mode selection is 13-20, but yours is showing channel 25. Am I missing something?
So looks like a screen upgrade is in order. Can't have the screen going dead on shoots. It looks really bad to production. I just looked up processors and see that the pro does have the fastest processor, graphics card and motion co-processor. More then my desire for the thing to be small and easy to carry, performance it #1. So is there a "don't be a moron, get the pro", a "you might see a slight difference", or "naw, don't waste your money" difference?
You would need to do a upgrade ( hack to 32 channels ) to the Go app , it is fairly simple but will not really solve your problem if you have a slow processor, I would say it would help if you were in a crowded frequency environment . I think channle 20 works great , and you should trty this first before loading this to your go app .
Ok to answer your question on if you should get an I pad Pro with all the fixin's . If you are doing this to make a living or supplement your income then I would say 100% ABSOLOUTLEY - sounds to me with your terminology on shoots and what not that you need something like this . I would get the I pad pro , standard size with GPS and Cell with 128 memory . I have talked to folks who fix these at Drone shops and they say this is the fastest best processor out there and is the benchmark they use . If I were you I would go to Best Buy , get and I pad Pro and test it out , if it does not work then you know it is something else. Best Buy has a very generous return policy and if it does not work simply take it back , I buy All my DJI equipment through them and they are great ( this has been my experience anyway ). I mean you can't go wrong here . My only concern is the screen going black on you , that may indicate a bad connection between the Gimbal and the vibration board , hard to say for sure , If you have checked that and they look good at the least be sure to clean the contacts for sure regardless then go get the I pad , I can't tell you how many e mails and notes I have gotten saying this solved the problem , I have ALSO HAD some members accusing me of working for Apple and trying to sell there I Pads, ( I laugh in there general direction ) I can't say for sure it will solve your issue but it is sure worth a try.
Also if you wish you could do the upgrade to the go app IF YOU ARE IN A CROWDED frequency environment , if not it wont help you . There are several videos on line , you will need I tunes loaded to your PC or MAC and then you simply add the file , nothing to it , then you can delete it if it does not work , easy peasy lemon squeezey. any way let me know but I think You will be In NIRVANA ( spiritual enlightenment ....not the Band ) if you get the I pad PRO .
You could also get the I pad Air , but it is not as fast and to me if you are gonna spend some dough , spend a little more and get the best . Also like the MINI 4 may get you by , the I pad air will work but NONE have the same power as the I pad pro with GPS Cell and 128 mb memory is the TOP OF THE LINE in my opinion .
You dont happen to live near East Lansing Michigan do you ? , You could use mine if you do ...... believe it or not I have met members who did not live to far away and I have helped them..... small world sometimes , never hurts to ask
**** regarding the Litchi app, I know some members who love it, but I know persoally members who have lost thier systems using the App, there is curently some glitch with it causing the AC to land halfway through a Mission , I dont know all the details but I think sticking with the Manufacturers Apps is always the best Idea, not saying Litchi is not good, and I do not have it on my sytem . Also if you are in the Warrenty period and have a crash ,DJI may use this as a reason not to cover a accident .-
"So dont be a Moron and get the I pad pro is my vote"......... LOL
Here is a link to the RAR file that you will need ( 32 channel update ) , it is hard to find so here is the link , once again go to you tube and in the search put "DJI 32 cahnnel hack" and youy will see several videos, there is one by a guy named Ben that I like to use .
https://www.rcgroups.com/forums/ ... ttachmentid=8474424
donnie
donnie
