fansa84fe8a4
Both my Samsungs do that, when they finally connect. You might try going into the HD setting in GO 4 and Manually select a channel that is in the green rather than letting Auto channel run. Then drop the speed slider under that to as low as it will go: 4 Mbps or lower?). It might help a little bit, and might cure it, but mine still breaks up but not as much as when in Auto. On mine, the longer GO runs the more they break up. Device gets hot and performance lags along with the feed. I've done the rollbacks and seen minor improvement.
Best advice would be If you want less video feed issues, look at an Apple Air 2 or iPad pro 9.7" model with cellular. Not perfect, but 95% better than my Samsungs and their feed and connection issues.
