DJI GO UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1537 9 2017-4-28
fans1f456478
IF YOU HAVE AN INSPIRE 1 PRO, DO NOT UPDATE THE DJI GO APP!!!!
I tried it an everything fell apart.  Slave or camera controller does not control the camera - in fact you can start the Inspire motors!  video feed is useless, lags, goes black, pixelates, etc.  they say a solution is ongoing.
2017-4-28
DJI-Jamie
Flight distance : 112405 ft
Could you please verify what Go app and firmware versions you're running?
2017-4-28
fans514bba19
India
Dji hurt for inspire 1 update i shame i have 3 inspire in my kit
2017-4-29
DJI-Jamie
fans514bba19 Posted at 2017-4-29 23:00
Could you please elaborate as to what firmware you're on and what kinds of issues you're experiencing?
2017-5-1
fans1f456478
DJI-Jamie Posted at 2017-4-28 19:09
I updated to the DJI Go 3 app version 3.1.10
2017-5-5
fans1f456478
fans1f456478 Posted at 2017-5-5 07:44
and according to DJI tech support, I'm running the latest aircraft, camera, and controller firmware
2017-5-5
DJI-Jamie
Are all the Inspire's components up to date as well? What mobile device do you use?
2017-5-5
suomipilot
Finland
Two Inspire 1 drones and five iPad. Picture signal misses a four-second intervals. Impossible to work. All of these defects as thunder from the sky, WHY DJI!!
2017-5-8
DJI-Jamie
suomipilot Posted at 2017-5-8 09:18
What are the iPad models of the ones you're using? If you've noticed this after a firmware update, try the following button combinations:
Reset the RCs of any odd presets:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
I'd recommend manually relinking the RCs to the aircrafts to ensure the connection is solid after resetting:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
2017-5-8
Donnie *
Flight distance : 3636782 ft
Get an I pad pro and I bet all the issues go away , the other versions will work but if you are in a hostile frequency environment it just wont cut the mustard .
Get the I pad Pro with GPS and cell with 128 memory , this is the Very best processor out there and I would bet money it solves your issue .
donnie
2017-5-9
