Cetacean
Flight distance : 2528264 ft
Frenck Posted at 2017-5-2 02:13
I also noticed the same problems, and I noticed that the DJI GO4 application is not stable, it does not receive the commands from my remote control and then freezes. Could it be the firmware?
Aloha Frenck,
If your DJI GO 4 app is not stable, you need to reinstall it. If it remains unstable, we need to discuss the specifications of your device that is running DJI GO 4. Old or low powered devices can make DJI GO 4 unstable.
If you ever suspect that your firmware is creating problems, refresh the firmware. In the case of your device not receiving commands from your remote controller, the problem may be your cable. If you have an iOS device, you have to use a Lightning Cable. There are many other solutions to your problems.
Your problem does not seem to be Active Trak but is more broad. Try to identify the problem better and start a new thread so we can help you with your problem. I will look for it.
Aloha and Drone On! |
