Simon Child
Flight distance : 153852 ft
Geebax Posted at 2017-5-6 20:05
I am not sure how much use a polarising filter would be if it slips inside the behind the UV filter. How would you adjust it?
How do you adjust it anyway when it is 400ft in the air : )
This slip-in one is notched so you know which way you are installing it. In fact it is intended to be used in the same orientation for all uses, which works out pretty well. If using it much off that default then it may leak light through the notch.
Polarising filters have the most effect when 90degrees to the sun, so set it in that default position i.e. horizontal, and it will have the most effect when facing the way that polarising filters work best.
When facing the sun or away it will have little effect, but probably wouldn't have much effect even if you could adjust it.
And if somewhere between it will have some effect, but I agree not as much as if you could rotate it. I suspect it only really matters if you are planning a specific shot and take account of the sun position and adjust accordingly before you take-off.
I have done any specific with/without comparisons, but my impression is that it doesn't seem to cause any harm in any orientation of the P4, and seems to be generally useful.
