NORMAP
zanek012 Posted at 2017-6-7 13:58
My bad, I hit enter and didn't realize that would post. Here are my estimates:
4500mah battery capacity at ~15minute flight time gives an average discharge rate of 4c. Assuming the Matrice hovers at around 1/3 throttle, I would estimate the battery discharge rate to peak at around 12c. Given this, I would guess they made the batteries 15c discharge rate for a small safety margin (my estimate of hover at 1/3 throttle may also be a bit much, realistically it may hover at closer to 1/2 throttle). Since the TB48D is a bit higher capacity it will probably have a slightly lower C rating
Thank you sir, that makes sense!
