Share your DJI GO Flight Records
2368 17 2017-5-2
RedTailHawk36
Flight distance : 978553 ft
I looked for a post on this but couldn't find it.
Interested in all the stats and what kind of Preventative Maintenance you've done if any?
After having the drone since March 8th, 2017 here is where I'm at:
Growth of Value : 0 (now). Was at 436,328 and climbing but for some reason reset to 0 along with my LVL.
Flight time: 21 hr 48 Min
Total Distance: 1,083,849 ft (205 mi).
I love this damn drone.  Crashed it 3 times already and it still works great.
Only had to replace the props and gimbal plate. No PM has been performed. I haven't read that it requires any.
Flight Record
Flight Record
2017-5-2
Lok Mavic
Flight distance : 1486660 ft
Hi Red, maybe syncing the flight log will solve the issue.
2017-5-2
DroneFlying
Flight distance : 10774613 ft
What does it show on the other two pages? In other words, what do you see if you swipe left from there?
2017-5-2
The Doctor
Flight distance : 258186 ft
Sweden
Blimey, I've had my Mavic for about the same time and only covered 38Km (24 miles)! Weather in Canada must have been better than the UK....too windy for my Mavic!
I'd be interested to know what people think about regularly changing props as a preventative maintenance measure since they are a single point of failure (the Mavic having a lot of other redundancy built-in), and if so how often (time or distance)? Or am I just being overly protective?
2017-5-2
NavigatorNL
Flight distance : 700768 ft
My stats:
MavicStats
MavicStats
2017-5-2
patman89
Flight distance : 288327 ft
Had the same issue while running an older version of the app. Have you installed the latest available update?
2017-5-2
RedTailHawk36
The Doctor Posted at 2017-5-2 09:57
On a side note I noticed one of the three (3) pegs sheared off after an accident and I didn't notice until I inspected all the blades...
The loose little tab rolling around in there could have caused a big problem in the motor.
I think regular blade inspection is really important. Removing and inspecting all of it.
2017-5-2
RedTailHawk36
You must be taking off snapping a few shots and landing. Only 71 Meters distance traveled?
2017-5-2
NavigatorNL
RedTailHawk36 Posted at 2017-5-2 18:09
No, 71-plus kilometers that is
2017-5-2
patman89
The flight records got strange for me... Yesterday I have synced my flight records and suddenly one of my flights was recorded as Inspire 1 (I don't own a Insire 1). Since that happend I have a mysterious DJI Aircraft in my profile. Next odd thing is that my "Top altitude" is around 4500 Meters. But I never went above 800 Meters (sea level).
2017-5-3
RedTailHawk36
NavigatorNL Posted at 2017-5-2 23:41
Oh Snap! Nice!
2017-5-5
Mafia16
Flight distance : 26490948 ft
Dominican Republic
These is my entire flylog and the other one is the Mavic
Main
Main
Mavic
Mavic
2017-5-5
adrian8891
Flight distance : 2643110 ft
Luxembourg
Here's mine
2017-5-5
AACY
Flight distance : 518012 ft
China
Only preventive maintenance that I had heard is to change the props, I believe that is after a year of flying. But there was a post about by Mindy.
2017-5-5
cl9988
Flight distance : 9743747 ft
My profile on this forum isnt right.  I think it might be limited to only 3 aircraft.
I have (3) Phantom 3's, (2) Phantom 4 Pro's and a Matrice 100.
My Growth of Value is 3,158,477   LV39
Flight Time:  129hr 36min
Total DIstance 7,587,466
Total Flights:  616
Top Speed:  58.3mph!!
2017-5-22
RedTailHawk36
cl9988 Posted at 2017-5-22 18:04
That's an impressive top speed!
2017-5-31
Szikra
Flight distance : 181211 ft
How can I see my flight stats online? If I sync them by clicking the cloud icon, is that only stores my data online for the mobile app to be able to pull it? Or it syncs and somewhere on dji.com I can see it through maps in detail? I want to analyse it on my PC.
Please help. (I am new :-0)
2018-1-7
Bekaru Tree
Flight distance : 15513100 ft
South Africa
got my mavic in march 2017 - crashed it 2 days later -was sent back to china and had it back since july 2017.
Flight distance 937km
Preventative maint.
1. i have wiped down the outer casing with a damp cloth about 3 times including tonight
2. during the wipe down i do a visual and tactile inspection of my mavic
3. Changed my props after first crash - bascially flown my full milage on my current props and they still seem perfect
4. Have noticed a fine layer of rust beginning on the springs over the prop shaft tonite - not urgent
5. i check for hairs or debris on the battery circuit connectors - never had an issue with it
6. i frequently check my batteries for swelling - On one battery some months ago i began to receive error messages through the app - visually it looked fine however i touched it to my lips once to feel its temperature and felt a slight bump indicating a lightly swollen cell. Fortunately i was still in warrentee so i sent it back and 5 months later i have received a courier note to say it is on it way to me.
Now i check my battery after most flights by brushing it over my lips when i remove/replace my battery.
7. Regular cleaning of lense filters - some places cause the lense to get dirty quicker than other places - cleaned my lense nicely 2 days ago and was surpised how dirty they were and i had not noticed (except eventually when my image quality was fuzzy again and i went looking for the problem)
2018-1-7
