hallmark007
Flight distance : 9827923 ft
PM160Mavic Posted at 2017-5-3 13:22
When you calibrate anything, it's ok to hold the controller and cell phone correct? I see somewhere it says to not have a cellphone near by, but you have to follow instructions on how to calibrate it and they show up on the cell phone.
Use this as a guide when calibrating compass, but as I said no need unless you are prompted
Many things can distort the earth’s magnetic field in the area you are flying:
Steel framed or reinforced concrete buildings, bridges and roadways, iron pipes and culverts, high power electric lines, heavy equipment, trucks and automobiles, steel tanks, electric motors and even computers.
Flying between steel framed or reinforced high rise buildings will distort the magnetic field in addition to causing GPS multi-pathing.
Safe distances for compass calibration
6” (15 cm) minimum: Metal rim glasses, pen/pencil, metal watch band, pocket knife, metal zipper/buttons, belt buckle, batteries, binoculars, cell phone, keys, camera, camcorder, survey nails, metal tape measure.
18” (50 cm) minimum: Clipboard, data collector, computer, GPS antenna, 2-way radio, hand gun, hatchet, cell phone case with magnetic closure.
6 ft (2 m) minimum: Bicycle, fire hydrant, road signs, sewer cap or drain, steel pole, ATV, guy wire, magnets, chain-link fence, bar-wire fence, data collectors
that use a magnet to hold the stylus.
15 ft (5 m) minimum: Electrical box, small car/truck, powerline, building with concrete & steel.
30 ft (10 m) minimum: Large truck, metal building, heavy machinery. |
