32 Channel Hack for P4P+ ?
4498 19 2017-5-4
DoctorRennie
Hey guys,
Do you know if there is a way to get the 32 channel hack to work on the Phantom 4 Pro + (with the build in screen)?
Thanks,
Scott
2017-5-4
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Yes it can work on 32 channel and I have done for this.
2017-5-4
dronist
Nelsonlee Posted at 2017-5-4 16:02
[view_image]
Nelson, He is also asking HOW DI YOU DO IT?
2017-5-4
Nelsonlee
Malaysia
dronist Posted at 2017-5-4 19:00
I can make a video to presenting you, but i worry after i posted here then admin forum will banned me again.....
2017-5-4
DoctorRennie
Nelsonlee Posted at 2017-5-4 22:29
Can you send me a PM?  Thanks!
2017-5-11
Nelsonlee
Malaysia
DoctorRennie Posted at 2017-5-11 21:56
Check your PM.
2017-5-12
14jnewmy14
Flight distance : 452835 ft
Out of curiousity, what is the benefit of doing this?
2017-5-12
Nelsonlee
Malaysia
14jnewmy14 Posted at 2017-5-12 08:22
Tips for extend the range :
You should install a firmware update to increase your channels to 32 channels prior to installation. (Higher channels have less WiFi interference and our antenna was customized for DJI 's light bridge system)
2017-5-12
14jnewmy14
Nelsonlee Posted at 2017-5-12 19:14
Which firmware update increases to 32 channels?
2017-5-12
Nelsonlee
Malaysia
14jnewmy14 Posted at 2017-5-12 21:56
Any firmware can be enable this 32 channel.
You need to add the (.DJI.configs) file into the dji go folder.
2017-5-12
14jnewmy14
Nelsonlee Posted at 2017-5-12 22:06
Can you send me a pm explaining this in detail more along with the video you sent above, when you have some free time, I'd appreciate it
2017-5-12
Nelsonlee
Malaysia
14jnewmy14 Posted at 2017-5-12 22:27
I cannot post here.
Please go to my youtube channel to get for it.
https://www.youtube.com/user/nelsonlpf
If you happy with it please subscript on my channel.
2017-5-12
14jnewmy14
Nelsonlee Posted at 2017-5-12 22:59
I cannot post here.
I'll check it out. Thanks
2017-5-13
DoctorRennie
14jnewmy14 Posted at 2017-5-13 07:40
Thank you very much!  For some reason it worked when the Phantom 4 Pro Plus was off, but when I turn it on, the additional channels are not available.  Weird.  Anyway, I think that 5.8Ghz seems to work better in my area too - plenty of range for everything I want to do.  2.4Ghz would be nice in rural areas, and I wish the channel hack would work consistently.
Scott
2017-5-13
djiuser_tZT2oupNlcd9
Flight distance : 1509150 ft
I cannot post here.
Nelson,
Does the 32 channel hack work on P4? I recently purchased and would Like to try this but all attempts so far to enable 32 channels has failed. I am running all the latest firmware. I have also purchased and Inspire 1 GL658C and linked this to the P4, this doubled my range to 2 miles (3.2 km).
Any other suggestions for getting the maximum range out of the P4?
2018-4-23
SM-17
Flight distance : 179288 ft
Malta
32 channel via dji.configs stopped working on dji go4 above 4.1.13 (dji disabled the parser)
2018-4-23
ROKI
Croatia
what is the message obstacle sensing will be disabled when aircraft is landing fly with caution ?
2018-4-23
Eric13
Flight distance : 13982031 ft
SM-17 Posted at 2018-4-23 08:29
That channel hack was wishful thinking.
The drawback was that any channel being chosen besides the preset ones had to be chosen manually and it wouldn't change - even if signal strenth altered.
You would select a channel before startup - where you and the drone are - and the drone would stick to that channel way out there.
I believe in channel scanning continouisly...
2018-4-23
CM17X
Flight distance : 1489554 ft
Colombia
What kind of sorcery do you have to type into that config file?
2018-4-23
Nelsonlee
Malaysia
djiuser_tZT2oupNlcd9 Posted at 2018-4-23 07:47
Nelson,
Double the range you can replace the stock antenna to ARGtek Antenna.
2018-4-23
