Marvin Yoon
Flight distance : 204144 ft
South Korea
Technically, it is impossible if you use all the DJI devices using WIFI connection because WIFI connection only allow you to connect one AP at a time.
But also technically, using DJI GO under connection of WIFI with your OSMO and use GO 4 under connection with your remote controller, that probably can let you connect with your two devices.
Anyhow, I think using two different smart devices would be the pretty much better way because using two DJI devices at one device means more battery consumption and always requires switching apps. |
