Phantomski
Flight distance : 14869882 ft
endotherm Posted at 2017-5-6 10:21
I did notice the aircraft got hit by a few gusts at various times throughout the flight. Even though your speed was negligible or stationary, it recorded a varying pitch between +30° to -30°, almost the limit of controlled flight. This seemed to occur as you ascended/descended through various altitudes, but they were extremely narrow pockets of turbulence if it was this explanation. I wonder if the sudden leaning over was enough to make you momentarily lose reliable GPS contact with all of them, and it momentarily switched across to ATTI? The number of detected satellites in the logs remained constant at 16, but perhaps some were found to be "unreliable"?
The camera gimbal is capable of a very wide range of movement, far in excess of the airframe in stable flight. Even if the aircraft were blown beyond the 30° it would not affect the gimbals ability to stabilize the camera and show a level picture. As I understand it, the gimbal gets its orientation from an accelerometer located in the lower flat gimbal plate with the rest of the camera processing circuitry and microSD card. For it to get confused about where "level" is located, it would need to be hanging under the aircraft at around 45°, which obviously wasn't the case. Are you sure you didn't just accidentally hit the mode button underneath the controller momentarily?
my c1 is camera up/down, my c2is front lights on/off.... so no way it went into gimbal mode change... weird.. isn't it? wish i was recording a video, but i was not....
Oh well, will watch the bahavior..,. This craft is over a year old,.. perhaps things are beginning to act funny....
I agree, gimbal can handle way more than 30deg.
The wind was not bad, overall... i have flown in stronger gusts....
DJI - is there any sort of diagnostics I can run on my own?
Oh, I will see if i have cached video by any chance.. that would be one way to see what i saw.... forgot about that, but i think i did clear the cache.. will check....
