Donnie *
Flight distance : 3636782 ft
Sounds to me like there is a corrupted video module on the X3 that was used and just purchased . You say that you can take pics with it but get no image is that correct ? If so then more than likely the camera would need to be sent in for repair . ( You get no video image on BOTH OF THE AIRCRAFT YOU ATTACH THIS USED X3 TO CORRECT , THE CAMERA IS UP TO DATE AS WELL CORRECT, if so read on . )
OK, here we go , you say that the latest FW is loaded to this X3 that has the problems correct ? if so what I would do is place the Current FW that is on that X3 ( you say it is the latest FW ) and AC and load it again to the AC via this problem camera , now you are not actually updating but you are just getting data off the SD card , now since the X3 and AC are up to date you will only wait a few minutes and you will have the data we need, now take the SD card and load it to the Computer and look at the Hidden file , If lines of code 0800 and 1500 say " Device Not Detected " then you will need to send this camera in for repair , now way around it . If it does not say that , then you may have another problem , let us know , but my money is on this .
Below is a link on how to view the hidden file if you dont know how, it is very simple .
How to View Hidden Files: Tool to diagnose No signal and SD Issues
donnie
Below is a sample of what a corrupted video module will look like on the Log of the SD card , the latest Firmware data will be on the VERY BOTTOM OF THE LOG PAGE so look to that data as the others will be from previoous updates , notice lines 0800 and 1500 . ***
Sadly on line ( ebay and what not ) I see this problem all the time , the seller corrupts the camera and then sell it and say , gee , worked for me . It is not usually an expensive fix but you must send it in for the video board to be wiped clean OR they replace the video board depending on what is wrong with it . The video module can be corrupted in many ways but the most common is leaving the RC transmitter on when updating the Aircraft with the latest firmware ( any version ) . That is the most common reason I have found for the Video module getting corrupted , that is why you NEVER have the RC transmitter on when updating the Aircraft OR the Aircraft on when updating the RC transmitter ...........You did not have the RC on when updating the used camera to your system did ya??????
[00014450]========== 2016.03.28 18:10:01. boot(15) ============
[00014487]Packet [C:\P3X_FW_V01.07.0060.bin] detected, card sn [0x6d851758].
[00014521]Packet upgrade start...
[00014560]Packet checking...
[00014603]Packet vlink 01.07.0060 <-> 01.06.0040.
[00014640]Record vlink 01.05.0030 <-> 01.04.0010 (flow = 0).
[00014678]Done.
[00014715]Version checking[1]...
[00014780][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014860][03 06][00] v2.4.13.0 -> v2.4.13.0
[00014903][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015020][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015099][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015202][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015300][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015400][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027944][15 00][00] device not detected.***
[00028023][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028143][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028202][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028244][01 00][00] v1.29.4920 -> v1.29.4920
[00028286][01 01][00] v1.29.4920 -> v1.29.4920
[00040820][08 00][00] device not detected.***
[00040879][09 00][00] v2.13.0.0 -> v2.13.0.0
[00040913]Packet upgrade failed at version checking.
