What firmware does my drone runs on?
1477 7 2017-5-7
Tomas Medek
Flight distance : 399190 ft
Czechia
Hello there.
I have Phantom 4 Pro Plus (the one with build-in display) and I am experiencing very strange situation. DJI Go app keeps telling me that drone has latest firmware. But DJI Assistant keeps telling that I have old version.
Also - when I try to upgdare firmware via DJI Assistant it just download it but then nothing will happen:
2017-5-7
Struzzinho
Slovenia
I have the same problem. You can check all the solutions guys gave me here http://forum.dji.com/thread-94029-1-1.html
2017-5-7
Tomas Medek
Czechia
Yes, I found your post yesterday and I did everything. And it is still the same - app says that V01.02.0304 is the lastest and DJI Assistant says that the newest is V01.03.0509 but when I try to update it stops on 100% download and then nothing.
Is there a way to update from SD card? How? And where to download firmware?
2017-5-7
Struzzinho
Slovenia
Sorry my friend I can not help you with that. Tell my how do I put Flight distance to my account.
2017-5-7
Antonio76
Flight distance : 144403 ft
Denmark
Struzzinho Posted at 2017-5-7 02:27
You have to sync  your flight records first, from within DJI GO 4. Main screen, tap on the top right corner and select "Flight record" , then on the top right corner, just above the Flight List, there is a small cloud icon. Tap on it and then follow the small window that opens.
2017-5-7
Struzzinho
Slovenia
Antonio76 Posted at 2017-5-7 03:06
I will try that thank you
2017-5-8
Tomas Medek
Czechia
Well, friends! My drone is updated! After 4 home computers I tried fifth one and everything works fine. I have no idea why Maybe something about drivers..? Who knows. But still - if you have the same problem just try different computers till succes.
2017-5-11
Struzzinho
Slovenia
Tomas Medek Posted at 2017-5-11 04:46
Yeah my friend I tried to update it on diffrent laptop and it worked. And guys from onedrone told me that you can alsoconnect your RC to wifi and update it via RC.
2017-5-23
