Bradders
Flight distance : 862283 ft
Hi Hallmark, Yes thankyou ! I was lucky enough to find it despite it not being in the same location as it originally lost signal. I think I might have found why it disconnected from the controller because I believe it has caused a new problem where the Mavic does not connect to the controller at all.... when you leave the battery in for just a couple of mins, the gimbal is go hot to the touch, so hot that you cannot keep your finger on it for a few seconds, this cannot be normal !
The reason why I think this is the issue is because, if you leave the Mavic over night then it connects however as soon as the gimbal over heats again then the Mavic will not connect to the controller
Cant afford another Mavic, but picked myself up a Phantom 3 Standard and going to get the Mavic sent in under warrenty
