fansc3e296fa
Mexico
TruGreen Posted at 2017-5-7 13:08
place drone on a flat smooth surface. turn on the drone, then turn on the remote. then on the remote the little switch around the "return to home" button toggle that up and down 4-5 times and drone should raise into the landing mode. turn the drone off and attach the gimbal. turn drone back on, after the camera rotates and does its check you should be able to hang the drone and toggle the switch up to raise the landing gear into fly mode.
hope that helps
Hello TruGreen,
we have the camera on the drone and have it in the landing position with landing gear down. The issue is that we need to run the drone motors in order to bring up the landing gear to the flight position.
My question is, if there is a way to have the drone in flight position with the landing gear up WITHOUT running the motors.
S.O. wrote that it is bad for the motors to run without load. Is that true? Cannot imagine why? |
