BenEphla
Got the Phantom 3 Standard, followed the set-up procedures, flew for about 10 minutes, then had to land after hearing a beeping sound once the gimbal became unresponsive. Took the drone home, searched online to see if anyone had similar issue, after reading through solutions of similar problems, such as gimbal disconnected, and beeping with no results in fixing my issue I come here to seek some help with my problem, I really hope someone can help.
I'll begin by explaining exactly what the issues are then go on to what steps I've taken to fix the issues from what I found online. Like I said, flew the drone for about 10 minutes, then had to land after I could hear a beeping sound, and gimbal became unresponsive. Got home, charged the controller, drone, and iphone after reading beeping sounds are generally caused by low battery (although I had only used about 1/3 of the 30 minute fly time battery life), still no luck.
Then I checked my setting using the app, and I saw "Gimbal Disconnected" in the Aircraft Status menu under the Gimbal Status section. I then googled fixes for a disconnected gimbal, and followed the instructions of checking the cables that connect to the gimbal, and gentle pushing them into the fitting, still no luck.
I am at a loss at what other steps I can preform, however I did read something about firmware updating, however I am unsure on how to do an update, and after watching a video connected to this suggestion only recommending this step if you know what you are doing since this can cause serious to the controller detecting the drone. Please if anyone knows of a fix I can try I'd greatly appreciate the help. |
