StanfordWebbie
Flight distance : 178018 ft
Just to check things, I too had a crash and the gimbal assembly broke free from the drone. It was quite easy to simply plug the two wire assemblies back into the gimbal assembly. Just look at it for a minute or so and you'll see how they fit together. Then, I replaced both plastic pins (remember - only two should be used - not 4) and all 4 white rubber dampers. I pushed the white rubber dampers through the bottom plate and then mounted the gimbal with the two pins. I got a vibration as soon as I flew - and it took a few minutes for me to realize that I needed to push the white rubber dampers into the TOP plate as well as the bottom. Anyway, as soon as I fixed that problem, everything began working perfectly. If you didn't order spares for the pins and dampers, they're easily available. |
