Override Altitude Limit
2084 6 2017-5-11
Koavog
Flight distance : 1359800 ft
Is it possible to override the 200 meter max altitude limit? I need to climb from take off point 300 meters to survay a ridge. There is no access to launch from ridge. Any suggestions or help is appreciated. Thanks
Peter
2017-5-11
DJI-Jamie
Flight distance : 112405 ft
The max altitude is 500m, so it should work. In addition, taking off at a higher point would help extend the height cap from the take off point.
2017-5-11
fansceff17c6
Flight distance : 1834360 ft
Croatia
DJI-Jamie Posted at 2017-5-11 20:45
So how do you set a higher max altitude?
Tapping, holding or sliding does not help. I've tried to set it to 500 in DJI GO first, but no changes.
DJI, anyone?
2017-5-25
DJI-Jamie
fansceff17c6 Posted at 2017-5-25 00:26
The altitude cannot be any higher than 500m from the home point. If you want to get the most altitude coverage you would want to take off as high of a point as possible.
2017-5-25
fansceff17c6
Croatia
DJI-Jamie Posted at 2017-5-25 08:30
Not higher then 500m. Higher then 200m.
Perhaps I am in the wrong thread and we misunderstud us.
I am talking about GS PRO. It has the altitude limit of 200m. I would like to set it to 300m.
2017-5-25
fansb8b222f3
Flight distance : 74213 ft
Sweden
Yes , I would like to be able to have height above according to surrounding Terrain . Meaning if its flat 500m is ok. If its the alps + 500m to the height of the mountain.
2017-7-29
fansb8b222f3
Sweden
Meaning addaptive height limit. Beeing 200m or similar
2017-8-2
