dr.nick
I have an Osmo+ and have used it both with Android and iOS. It's a great little toy but not for professional shooting. Doing hiking timelapse etc it would be awesome. It's super light weight and can do things no other camera in the world can do, particularly at this price point. But go in with your eyes open and know that it's also terrible in ways that no other camera in the world is terrible.
Here are some answers to your questions and what I wish I'd have known before I bought ....
Battery life is decent, about an hour with the high capacity battery. The 9min+/- limit in 4K (18min+/- in 1080) is the record run you can get in one continuous uninterrupted clip. It's actually tied to the 4G file size limit not battery life. When the Osmo hits 4G it starts to write a new file and in the process loses about a 1.5 seconds of footage. No other camera in the world that I'm aware of has this glitch. If you're doing short clips or timelapse you'd probably never have to worry about it. If your recording some kind of event it's terrible because your footage will glitch at this point. There's also a hard stop at 30mins where the camera will stop recording and you have to hit record again. It'll obviously glitch there too.
Osmo is bad in low light and doesn't have great resolution (don't be fooled by 4K specs). However it is about what should be expected picture-wise from a camera with this size chip and this type of lens. In full sun it's perfectly acceptable and with the proper manual settings, a ND filter set, and some skill, people do get decent looking images out of it.
The software is glitchy but keep in mind DJI is having to write sophisticated code that will play well with hundreds of different devices in hundreds of different configs. In my experience, the iOS version is much more stable and more capable than the android version. The biggest base functionality advantage from my perspective is that DJI Go iOS allows you to zoom while pan/tilting, while the android does not. You'd use the DJI Go app not the Go4 with the Osmo. And evidently, there are issues going back and forth between the two.
Wifi connection isn't super robust, but not terrible if you turn off all the other phone/device wireless functions and apps and toggle the wifi between 2.4gHz and 5gHz to find what works best for any given location you're at. Interference from other devices and other apps running simultaneously on the phone/tablet undoubtedly causes many of the connection issues people have.
I (and others) find the Osmo to be frustrating because it could be great but there are just too many flaws in the implementation. For a someone wanting an interesting little camera to play around with as a hobby, it might be worth it depending on what you want it to do. For a pro or semi-pro doing professional work it's not reliable enough except for maybe a few niche uses. Although I've not used it myself in a hiking-timelapse capacity, theoretically that would be a perfect use for it. |
