Nigel_
Flight distance : 388642 ft
You could start by cleaning the springs with WD40 to remove the existing rust, then wash them in washing up liquid to remove the WD40.
Then use Vaseline as used on battery terminals to prevent corrosion,
or silicon grease is probably also good, as used on plastic suspension bushes.
Normal Lithium grease is probably OK too although you don't actually know what is in that and if it is designed to be compatible with plastics.
However I don't know what type of plastic it is so this is only a guess, some guidance from DJI would be good... |
