High altitude props
1103 7 2017-5-13
nzfritz
Flight distance : 263796 ft
Indonesia
Bought some high altitude props a few days ago...
Going for a test flight now and will report back what seems different.
At sea level today but will be up a mountain in a few days...
2017-5-13
nzfritz
Indonesia
Update: don't try them at sea level. The craft is super jumpy and twitchy. Will try at high altitude in a few days and update again.
2017-5-14
fansd845e849
Flight distance : 1495906 ft
Philippines
nzfritz Posted at 2017-5-14 01:46
Does that mean it's generating more thrust at sea level? So you have to set softer gains at sea level. I wonder if the acceleration and top speed are better with it. And payload capacity.
2017-5-14
nzfritz
Indonesia
fansd845e849 Posted at 2017-5-14 03:16
No sure... about all that, sorry.  Just got back from flying at about 8000 feet (not super high really) and tried them there.  Really smooth with almost no sound when thrusting straight upwards. Didn't compare with standard props, as I only had 2 pairs of batteries to shoot with all day....
2017-5-20
jimapp
Flight distance : 109505 ft
Am I missing something? I thought the drone could only be flown to 500 feet
2017-5-20
Cougar1
Flight distance : 924393 ft
jimapp Posted at 2017-5-20 14:47
In Canada you are limited by regulations to 300 feet or if your SFOC allows 400feet AGL (above ground level). OP is referring to his take off point as beiing ASL (above see level) so not related. Ex. he is taking off in mountain area vs. at the cost, booth would be limited to same height restriction, just different starting height.
2017-5-20
Nik6
Flight distance : 806096 ft
I've flown with the high altitude blades a few times at over 10,000ft. They preform really good, sound a little different at idle.
2017-5-23
WernerD
Flight distance : 350837 ft
No, thrust is related to the Watts the motor produces and that does not change just because your props have a different blade inclination. What does change is resistance and therefore the rpms.
In thinner air the resistance is less hence the rpms would go up to a level the motor cannot handle. Hence you increase the blade inclination to balance that out. In thinner air the rpms will be in the optimal range, approximately the same rpms you get at ground level with the regular props.
You could also argue the other way around. In thinner air you have to push more volume of air to achieve the same trust/Watts, hence higher blade inclination needed at the same rpms.
Makes sense?
2017-5-24
