After 2 Mavic units that wouldn't focus properly, I received my 3rd Mavic this weekend. I'm happy to say focus on this one is much better and all corners are acceptably sharp. However, here is a video clip of my first flight that is showing some significant side to side vibration. I did calibrate everything before flying and the gimbal appears to be seated correctly so I'm not sure what might be causing this.
stephen33 Posted at 2017-5-14 02:18
Worth mentioning that not all video was like this and it was not very windy. The shake did get noticeably worse later in the day.
That is not good. Suggest you contact DJI support on this one.
Please double check if you have removed all the stickers on the gimbal.
Then do the IMU calibration on a complete flat surface then gimbal calibration.
What's your current firmware version? Is the firmware up to date?
