Montfrooij
Flight distance : 2560453 ft
1. You are right.
2. The Go app has some settings that you can't change otherwise. BUT you probably only set them once and leave them like that for a long time.
3. I am not sure. It uses the Go app to capture images of each point. Not sure if it needs that to run. It might be worth a try!
4. It is the Go app, not the Go4 for Osmo Mobile. I have not tested it on an Android device yet. It probably also depends on the manufacturer. DJI's own crystalsky runs on Android. So it 'should' be possible.
5. That I don't know. I am no electrician. It has enough power for sure, but I don't know it it can handle the current it outputs.
You will have to make sure the combo balances right. Otherwise the motors will have problems balancing and you might end up with less stable footage and / or a broken gimbal.
I don't want to push you away from DJI (I love the Osmo Mobile), but if you want a Gimbal for your GoPro, why not buy one for the GoPro?
The GoPro gives great footage and if you already have it, why not use it with a gimbal designed for the GoPro? |
