fans4495a97d
Flight distance : 1873 ft
davawt Posted at 2017-5-21 12:07
You could try and change the fuse in the plug that goes into the wall socket, just change it for a new one the same amps, and then plug in and then switch the wall socket on, don't just plug the charger plug into a connector without the switch in the off position. I had this problem with my phantom, you need the wall switch off before plugging in the charger, hope this helps it fixed mine and now all is ok.
Bye,
Dave
Thanks Dave. Nothing else has worked, I'll give this a shot! |
