Phantomski
Flight distance : 14869882 ft
ok, so what u would want to do if this was a p3, u'd want to set your RTH altitude low, disable Smart Return Home, change settings to "hover" or "throttle down" on signal loss. Now that you know the rth altitude, take off from somewhere where flying the bridge will be at that altitude - this way in the unlikely even it does RTH, it will NOT ascend and hit the top of the bridge above it... So take off, fly and walk to your destination - then be ready to flip to ATTI mode in any sign of trouble.. You could consider filming 60 or more frames, as available, and fly through fast, then slow it down when editing the video....
That is all I can think of for now...
As noted above, P4 is a bit different story and so on.
Glad it worked out. When u gonna share the video?
