Dobmatt
Flight distance : 1831050 ft
You're right, motor booms are misaligned badly. The bird will fly somehow, compensating for different propulsion dynamics, but if hardware is loosely fastened it may become dangerously off and eventually fall apart.
Now, assuming that the small tubes below arms are manufactured and assembled properly, it is possible that the joint clamped around boom tube slipped off it's aligned position. Did you had hard landing or collision? This clamping is relatively easy to check and fix if you're comfortable with basic tools and have some mechanical skills. If not, the only way will be to send the bird for simple alignment since they're (DJI) using special jig to do just that. No big deal ...
PS. Dopiero teraz zauważyłem że gadam do Rodaka. No nie, Polak potrafi bez kłopotliwego servisu fabrycznego, ale - jesli sruba zaciskowa jest ukryta pod naklejką DJI - to możesz stracić gwarancję. Nie jestem pewien czy w tej wersji zacisk jest na wielowypuscie tak jak w moim I1P, sprawdź to i może zrób parę dodatkowych fotek z bliska w okolicach T-joint na rurze silnikowej.
