SkunkWerxs
Flight distance : 231217 ft
Tesla Posted at 2017-5-18 08:55
You may be able to use tweezers to carefully remove the upper dampening pad and gimbal from the lower pad. Be careful not to damage either of the cables to the gimbal. Then you may have access to push the rubber bands back into the lower dampening plate. Using dishwasher soap as fansc2962bbc suggests will help. You can then remount the gimbal and upper dampening plate to the rubber bands. However, if you stretched the rubber bands too much during the crash you may end up with an "Excessive Gimbal Vibration" alert and your video may be "jellowey". If this is the case you will need to do a complete tare down and replace the lower dampener pad. I have not found a place that just sells the rubber bands, nor just the lower dampening pad, so you may need to buy the upper and lower dampener pad together. You can get them on Amazon for around $15. Good Luck!
Tesla , Have you had the rubber bands out already
is it true that they would stretch if over stretched not only once but maybe a couple of time's ????
