Donnie *
Flight distance : 3636782 ft
Make sure you have the VPS enabled on the go app . If you do also inspect the wires going from VPS to the AC, a light cleaning is sometimes in order on the VPS , just a blow of air on the two screened sensor's and a cleaning of the opitical sensor with a lens cloth .
Make sure you are getting good data from the sensor at heights below say 3 meters. If after you do the above cleaning and making sure it is enabled it may need replacing .
donnie
