Check that the cable is properly connected. If you are using the side connector, then try using the bottom usb port on the RC but make sure you remove the connector from the side.
Run an App like CCleaner and remove all that is no longer needed on your phone. This will free up some memory and makes your phone run a little faster... No need to switch to IOS {:4_181:}
