Geebax
fansa84fe8a4 Posted at 2017-5-16 16:55
Typical lens flare.
Nothing to be concerned with, other than try and avoid off axis strong light sources to lessen the contrast, or maybe using a lens hood. The DJI lens is not some anti-reflection, multi-coated, and Nanao-coated lens that eliminates those reflections. If you want to buy some $20K cinema lens, you might get better results, although J.J. Abrams seems to push the effect a lot to his advantage in movies like Star Trek...sometimes too much for embellishment.
He is not talking about the lens flare. The title of the thread is: 'Error with video white and black spots appearing on my video'.
If you look in the bottom left corner of the clip you will see sparkling in the dark areas, this is what the OP is referring to. |
